Failed on "Homepage" [1 of 1] Error: couldn't resolve host name
  • hughmcl
    • Oct 2008
    • 20
    I've been using web monitoring for some time now with no issues, suddenly today for some reason, most of the web checks are coming back with:-
    I've checked and the server can both look up the IP address from the name, and i can use curl to get the webpage, both using http:// and not using http://. However in the web checks I'm getting the errors!
    27655:20090729:171505 Error doing curl_easy_perform [couldn't resolve host name]
    27655:20090729:171505 In process_step_data(step:Homepage,url:http://www.<hiddenURL>,rsp:0,time:0.000000,speed:0.000000 )
    nothing has changed on the server, so I'm pretty confused as to where the error is coming from!
    CentOS 5.3
    Zabbix-1.6.5
    3GB RAM
    MySQL-5.1.33
  • hughmcl
    • Oct 2008
    • 20
    I'm continuing to have this issue!
    Most of the time everything works fine, then in spurts we get lots of Web errors, and when i look in the logs:-
    Error doing curl_easy_perform [Couldn't resolve host name]
    I just tried upgrading to the latest curl today (recompiled zabbix agent/server). And again still getting the errors.
    Noone got any idea how to fix this?
    It recovers shortly after, but in the meantime it's already sent out alerts.
    I really like Zabbix, but I'm getting pressured from the helpdesk to replace it, since they get paged every time there's an issue! I don't want to replace it, but if we can't get this issue resolved, then I'm going to have to.
    Hugh
    • rgilchrist
      • Mar 2005
      Same Problem
      Hi Hugh
      Just wondering if you found any solution to this problem.
      I have experienced this issue serveral times, thought I had found a fix/hack by hardcoding the URL's & IP's in the /etc/hosts file. Which solved the problem for a couple of months, but all of a sudden the problem has started again. And I can't find a way to resolve it.
      Cheers
      Rob
      • wbro1
        • Apr 2009
        • 17
        Here's same issue.
        on zabbix server i can ping everywhere. But on web monitoring only get the anwser "Fail - Error: couldn't resolve host name".
        What's wrong with my Zabbix
