Can't select custom Graphs under monitoring on 1.6.5
  • emerzon
    • Apr 2008
    • 21
    I am having a weird issue with Zabbix 1.6.5.
    Whenever I try to select a custom made graph (Under monitoring, graphs), as soon as I click the graph name on the dropbox, the page reloads and gets me back to the first option on the dropbox (Select Graph...), as if nothing happened.
    Tried in Firefox and IE, both seen to have the same behaviour.
    Couldn't find any error messages on zabbix-server.log
    This is the HTTP capture of when I select the item in the combobox:
    http://hostname/zabbix/charts.php?si...027&graphid=20
    GET /zabbix/charts.php?sid=3b7c2b3b5af514e3&fullscreen=0&group id=0&hostid=10027&graphid=20 HTTP/1.1
    Host: hostname
    User-Agent: Mozilla/5.0 (X11; U; Linux x86_64; pt-BR; rv:1.9.1) Gecko/20090630 Fedora/3.5-1.fc11 Firefox/3.5
    Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
    Accept-Language: pt-br,pt;q=0.8,en-us;q=0.5,en;q=0.3
    Accept-Encoding: gzip,deflate
    Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
    Keep-Alive: 300
    Connection: keep-alive
    Referer: http://hostname/zabbix/charts.php?si...027&graphid=20
    Cookie: zbx_sessionid=678a47bd0be1b5773b7c2b3b5af514e3
    HTTP/1.x 200 OK
    Date: Thu, 06 Aug 2009 21:11:32 GMT
    Server: Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch
    X-Powered-By: PHP/5.2.6-1+lenny3
    Set-Cookie: zbx_sessionid=678a47bd0be1b5773b7c2b3b5af514e3
    Vary: Accept-Encoding
    Content-Encoding: gzip
    Content-Length: 2326
    Keep-Alive: timeout=15, max=93
    Connection: Keep-Alive
    Content-Type: text/html; charset=UTF-8
    The simple graphs under monitoring, Latest data works fine.
    Any clues?
  • richlv
    • Oct 2005
    • 3112
    does this happen with all custom graphs, including the default ones ?
    • emerzon
      • Apr 2008
      • 21
      Well yes it happens to all custom graphs I have.
      But I don't have any default custom graphs. My hosts are currently associated only with Template_Linux, that has no default graphs.
      • richlv
        • Oct 2005
        • 3112
        well, i don't have any good guesses. i'd suggest checking webserver logs, just in case
        • Calimero
          • Nov 2006
          • 481
          PHP's memory_limit too low ?
          • dsissitka
            • Aug 2009
            I believe the problem occurs when a chart's host does not belong to a group. See lines 121 through 134 of charts.php. As far as I can tell lines 132 through 134 are unnecessary and commenting them out appears to fix the problem.
            I hope it helps.
            • ray369
              • Jun 2009
              charts.php
              Thanks dsissitka,
              I added my host to a group and then the graph displayed just fine. Removed it again, and the page went right back to the (Select Graph...). Commented the lines you referred to and it works like a champ.
              • troffasky
                • Jul 2008
                • 640
                I'm seeing this too. Has anybody submitted a bug?
