Gaps with Fixed Axis on Graphs
  • bhatfield
    • Apr 2009
    • 11
    As can be seen in the graph below, there are some gaps. Please note, these are not related to missing data, but rather when I specify a fixed axis, if the data goes above the max, it shows a gap.
    An obvious expected behavior would be an entirely filled region.
    Bug, or fixable?
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Zabbix version?
    Zabbix | ex GUI developer
    • bhatfield
      • Apr 2009
      • 11
      Originally posted by Aly
      Zabbix version?
      It's been this way in 1.6.4 and 1.6.5 - sorry for lacking that detail.
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        Thank you. Registered as ZBX-1014 in bug tracking system. Fixed rev. 7783.
        • bhatfield
          • Apr 2009
          • 11
          Wow, that was fast. I marked my bug in the system as a duplicate of yours.
          I tried to find the zabbix source control URL, but failed. I only found CVS on sourceforge, which hasn't been touched since september 2006 - I'm curious to see a diff of what you had to change to fix this (I looked at trying to change it myself but couldn't figure out where the graphs were actually being drawn)
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            We have SVN repository: svn://svn.zabbix.com
            • bhatfield
              • Apr 2009
              • 11
              Thanks for this. I just backported your fix into my version of zabbix (it looks like you guys changed a LOT for the frontend, including renaming files, so I didn't want to mess with only upgrading the front-end) and it works like a charm.
              Thanks!
