Zabbix messages In System Event Log
  • Buxton69
    • Aug 2009
    • 31
    Is there anyway of changing the volume of messages that are written to the system event viewer log, the seems to be about 5 messages for every zabbix action and it doesn't seem necessary.
  • Buxton69
    • Aug 2009
    • 31
    Think I just solved ths as soons as I asked the question, I changed the debug level in the config file, is this correct?
    • Buxton69
      • Aug 2009
      • 31
      While I'm on the subject why is this this produced as a warning?
      [4252]: Info from server: Processed 100 Failed 0 Total 100 Seconds spent 4.690708
      Seems a little useless, it would be better if only failures were warnings.
