Error retriving some values
  • thelan
    • May 2009
    I'm new with zabbix and I don't understand why some values can't be requested properly by the server
    I got this problem only when the server is monitoring itself
    I've done a small test with the shell
    zabbix_agent -t net.if.in[eth0]
    net.if.in[eth0]                               [u|49011953502]
    zabbix_get -s localhost -k net.if.in[eth0]
    ZBX_NOTSUPPORTED
    I've compiled the last (1.6.5) version
    Thanks for your help
  • Calimero
    • Nov 2006
    • 481
    Configuration parameter Server= in zabbix_agentd must contain the list of IPs allowed to poll zabbix_agentd.
    As you're querying the server from ... the server, you should add '127.0.0.1' to the Server= list.
    • thelan
      • May 2009
      Yes sure
      i've put the ip from all interfaces of the server
      Ive only got partial answers for exmples when I query agent.version i got the right answer ( 1.6.5 )
      But i've tested with an other server this works perfectly
      Ive got the same problem with the proc.num[] functions
