SNMP agent uptime with 1.6
  • troffasky
    • Jul 2008
    • 640
    I'm could have sworn this worked in 1.4. What I want to do is monitor the uptime of a device with SNMP, so that I can alert if it goes back to 0 [ie somebody has rebooted the device or power has been lost]. I am using sysUpTimeInstance, which when polled with snmpget gives:
    .1.3.6.1.2.1.1.3.0 = Timeticks: (322630203) 37 days, 8:11:42.03
    If I create an item that's unsigned integer, units set to 'uptime', Zabbix tells me it's uptime is 3731 days, which is two orders of magnitude out. I have tested this on two 1.6.5 installations against two different SNMP devices and get the same results. Changing the units to blank confirms that Zabbix is getting the correct number of seconds.
  • richlv
    • Oct 2005
    • 3112
    from a quick glance (sorry, i did not have time before ), it looks to me that zabbix is doing everything correctly and snmp item is returning data with millisecond precision or something.
    i'm not aware of a simple shell version to calculate time period, but try something as simple as :
    date -d@$[$(date "+%s")-322630203]
    • troffasky
      • Jul 2008
      • 640
      If Zabbix is expecting seconds and the device is giving milliseconds, then presumably I could solve the problem by using a multiplier of 0.01, problem solved :-)
      • troffasky
        • Jul 2008
        • 640
        Indeed, a custom multiplier of 0.01 has fixed it.
        Question is, is this a bug in Zabbix? The 'timeticks' data type is hundredths of a second [not milliseconds]; Zabbix should be looking at the installed MIBs when trying to interpret data it's polling with SNMP. This would also eliminate the need to create throw maps and manually specify data types in many cases. There's already a feature request for this, so vote for ZBXNEXT-2 if you think it would be a good idea.
