Import and Export problem
  • marmul
    • Jul 2009
    • 9
    i'm using Zabbix to monitor several applications and servers. I'm very happy with it, but i have one problem i had to realize that the Web scenarios are not exported. It's not nice because it forces me install the web scenarios manually or via db scripts, if i want to preconfigure zabbix for our subsidiars.
    It would be nice if you put this on your road map for future developments. Another also nice useful feature would be to assign a web scenario to a template.(i think other user also would appreciate it...
    Regards
    Markus
  • emmanux
    • Mar 2013
    • 47
    You can use my script to do this. It creates templates in the new Zabbix Server, with the names of the hosts in the old one as hint. You need to apply those templates to the actual hosts in the new environment.
    https://gitlab.com/emmanux/zabbix-to...eb-migrator.pl
