Triggers and Templates
  • navtek007
    • May 2005
    • 100
    I have created a trigger for a template like the following:
    {Windows.Base:cpu_util5.last(0)}>85
    But when the trigger is linked to all the other hosts it subtitues the 'Windows.Base' for only one of the hosts. But it uses this host for all the triggers eg:
    {host1:cpu_util5.last(0)}>85
    For some strange reason it does not use the correct hostname. It should be the following
    {host2:cpu_util5.last(0)}>85
    {host3:cpu_util5.last(0)}>85
    Any ideas???
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It is already fixed. Will be available in 1.1beta1.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • navtek007
      • May 2005
      • 100
      great, is there a releaset date for 1.1beta?
      thanks.
      • jporter1
        • Aug 2005
        • 18
        Very interested in a release date also.
        Has the bug in James Well's post - "Annoying bug in current CVS tree" (can't add items from templates) been fixed in the beta version also?
        And screen/graph template linkage?
        Thanks.
