Trigger expressions
  • navtek007
    • May 2005
    • 100
    Trigger expressions
    I need to change a number of trigger expressions to the correct hosts, however when i query the trigger table for the expressions i get the following for the expressions:
    {11944}>0
    What does the "11944" represent? i thought that it could be hostid however my hostsid's dont go up that high. any other suggestions would be great. or maybe a fix to for the trigger template upgrade/update function that doesn't seem to work.
    Thanks in advanced.
  • slider_xtm
    • Sep 2005
    it is functionid from function table
    • navtek007
      • May 2005
      • 100
      great thanks for your help.
