ERROR: Invalid URL parameters
  • Fernandodesr
    • Sep 2009
    Hello, I'm using version 1.6.6, on CentOS 5.3.
    I'm getting the message "ERROR: Invalid URL parameters" in the following cases:
    - Assigning a template to create a host;
    - Add a host on a map.
    Could anyone help me?
    Thank you.
    fernandodesr.
  • richlv
    • Oct 2005
    • 3112
    have you tried with a different browser ?
    for the same browser, you could try clearing relevant cookies (and maybe browser cache)
    • Fernandodesr
      • Sep 2009
      In IE8 worked, but not in Firefox 3.5. It may be a bug in relation to firefox.
      Thank you.
      Fernandodesr.
      • richlv
        • Oct 2005
        • 3112
        so did you try clearing firefox history/cache/cookies (not all probably needed, though) ? that should resolve this problem
        • Fernandodesr
          • Sep 2009
          Hello, I cleared all firefox history / cache / cookies, but continues with the message.
          Thank you,
          Fernandodesr
          • Jason
            • Nov 2007
            • 431
            I'm having exactly the same problem with Firefox 3.5.4
            Works fine in IE
            • JSylvia007
              • Sep 2007
              • 29
              Also having the same problem with FF 3.5 / Zabbix 1.6.5 (Upgraded from 1.6.2).
              • Jason
                • Nov 2007
                • 431
                Is there a fix for this yet as I'm having the same issue with zabbix 1.8 and firefox 3.5.7
