node doesn't send data
  • stage
    • Sep 2009
    • 34
    I’m experimenting with distributed monitoring servers.
    With 3 nodes 1 master and two clients all zabbix 1.6.6 and all in the same network
    NodeID=1(Master)10.100.100.53
    NodeID=2(client)10.100.100.50
    NodeID=3(client)10.100.100.51
    Node=3 doesn’t wand to send any info to the master server.
    For both clients I have used the same installation procedure, I’m 100% sure that I didn’t do any thing deferent.
    For master
    Zabbix_server –n 1 –c /etc/zabbix/zabbix_server.conf
    For client 1
    Zabbix_server –n 2 –c /etc/zabbix/zabbix_server.conf
    For client 2
    Zabbix_server –n 3 –c /etc/zabbix/zabbix_server.conf
    In the GUI of the two clients I made the master server master type and in the master GUI I made the two clients remote type with the right IP ref. I multi checkt.
    In the log file of master node I can see the receiving from node2 but not from node 3
    In the log file of node2 I can see the node sending to node1.
    I can’t see any log of sending in node3.
    It would be great if you could help me.
  • zabbix_zen
    • Jul 2009
    • 426
    "I can’t see any log of sending in node3."
    Isn't that agent complaining with some error? It should say something helpful.
    Check if binaries/conf files permissions are the same for node 2 and 3.
