Windows unlettered mount points
  • dwiese
    • Dec 2008
    I have an Exchange server with unlettered mount points. Is there a way to get the current size of those drives? One of the mount points is called SG1DB and I have tried:
    vfs.fs.size[SG1DB,free]
    vfs.fs.size[/SG1DB,free]
    vfs.fs.size[\SG1DB,free]
    and all come back as unsupported? I've also tried pfree instead of free and that doesn't work either.
  • simonuk1
    • Mar 2009
    • 66
    You can use perf counter to get this sort of information, I had the same problem.
    I presume you have the drives mounted as folder for exchange ?
    If you do a typeperf -qx > typeperf and then open of that text file and search for the name of the folder it should give you info for how much space is used etc.
    Should be examples of using custom perf command in the agent etc to get his info.
    Cheers
    Si
    • dwiese
      • Dec 2008
      Thanks Si!
