Remote command truncated to 244 characters - v. 1.6.2
  • luissma
    • Jul 2008
    • 16
    When running a remote command from an action it is truncated on the agent side to 244 characters.
    Seen that OPERATIONS.LONGDATA is VARCHAR2(2048), where the command is stored, but it produces an error when running commands longer than 244 characters.
    Example:
    1.- Working command:
    Remote command:
    {HOSTNAME}: /usr/local/sbin/zabbix_sender -z <zabbix_server> -p 10051 -s {HOSTNAME} -k <trapper> -o "Short text `<command_that_produces_an_output>`"
    zabbix_agentd.log:
    3081:20091008:133401 Requested [system.run[/usr/local/sbin/zabbix_sender -z <zabbix_server> -p 10051 -s {HOSTNAME} -k <trapper> -o "Short text `<command_that_produces_an_output>`",nowait]]
    3081:20091008:133401 Run command '/usr/local/sbin/zabbix_sender -z <zabbix_server> -p 10051 -s {HOSTNAME} -k <trapper> -o "Short text `<command_that_produces_an_output>`"'
    3081:20091008:133401 Sending back [1]
    2.- Non-working command:
    Remote command:
    {HOSTNAME}: /usr/local/sbin/zabbix_sender -z <zabbix_server> -p 10051 -s {HOSTNAME} -k <trapper> -o "Very long text inserted to exceed 244 characters `<command_that_produces_an_output>`"
    zabbix_agentd.log:
    3083:20091008:133514 Requested [system.run[/usr/local/sbin/zabbix_sender -z <zabbix_server> -p 10051 -s {HOSTNAME} -k <trapper> -o "Very long text inserted to exceed 244 characters `<command_that_produces_an_o]
    3083:20091008:133514 Sending back [ZBX_NOTSUPPORTED]
    Found that DB field ITEMS.KEY_ is limited to 255 characters. Extended to 1024 to leave enough room for commands and changed ITEM_KEY_LEN in zabbix-1.6.2/include/db.h from 255 to 1024
    #define ITEM_KEY_LEN 1024
    Characters from 244 to 255 may be used for control or similar?
  • richlv
    • Oct 2005
    • 3112
    please report this on the tracker, thanks
    • luissma
      • Jul 2008
      • 16
      How (where) can I do that?
      • richlv
        • Oct 2005
        • 3112
        register at https://support.zabbix.com and report it there
