I've had this working before, but we've recently upgraded all of our machines and moved to a new datacenter, now I'm receiving partial updates from all nodes.
Zabbix 1.6.6
MySQL 5.x
After extensive reading and research, I have added the following to all my zabbix databases
This helped, the nodes started transferring data regularly however it does not transfer all the data.
I've modified server.c to increase my TrapperTimeout to 3600, recompiled and edited /etc/zabbix/zabbix_server.conf, under the assumption that the node sync was timing out.
This is the error message.
The symptoms is that my overview and dashboard are not showing change in triggers, however configuration changes are sent. So my dashboard, overview is not up to date.
In debug 4 I see several of the follow messages but no errors or timeouts.
Any help at all would be greatly appreciated.
Zabbix 1.6.6
MySQL 5.x
create index node_cksum_index_2 on node_cksum (nodeid, cksumtype);
20679:20091013:121836 NODE 1: Received history_uint from node 3 for node 3 datalen 238629 20679:20091013:122428 NODE 1: Received data from slave node 2 for node 2 datalen 8 20679:20091013:122937 NODE 1: Error while receiving answer from Node [2] error: ZBX_TCP_READ() failed [Interrupted system call] 20678:20091013:122937 NODE 1: Received data from slave node 3 for node 3 datalen 1752 20678:20091013:123454 NODE 1: Error while receiving answer from Node [3] error: ZBX_TCP_READ() failed [Interrupted system call] 20677:20091013:123800 NODE 1: Received history from node 3 for node 3 datalen 167417 20678:20091013:123815 NODE 1: Received history_uint from node 3 for node 3 datalen 280809
20927:20091013:125037 Starting sync with nodes 20914:20091013:125037 End substitute_functions() [1=0] 20914:20091013:125037 In evaluate(1=0) 20914:20091013:125037 In evaluate_simple(1=0) 20914:20091013:125037 In evaluate_simple(1) 20914:20091013:125037 In evaluate_simple(0) 20914:20091013:125037 End evaluate(result:0.000000) 20914:20091013:125037 End evaluate_expression(result:0)
