Hi
we have setup a distributed monitoring environment using version 1.6.6:
ZABBIX-Master <-> slave82 <-> slave80
All users are created on the master and the permissions are set for
the usergroup Win_Admin to see all hosts in hostgroup Win_Server
on slave80.
This works fine as long as we use internal authentication as
the system default.
However, as soon as we change the system default to LDAP authentication
and change the usergroup to use internal authentication, neither
the hostgroup is shown nor can the user select the node slave80.
LDAP authentication works fine, that is not the problem.
We appreciate any advice how to solve it.
Thanks in advance
Norbert.
on slave80.
the system default.
Thanks in advance
Norbert.
