WARNING: ucf was run from a maintainer script that uses debconf
  • Razique
    • Sep 2009
    • 19
    Hi, here is an error that I had to show to the package maintainer
    Achille:/usr/share/zabbix# dpkg-reconfigure zabbix-frontend-php
    dbconfig-common: writing config to /etc/dbconfig-common/zabbix-frontend-php.conf
    *** WARNING: ucf was run from a maintainer script that uses debconf, but
    the script did not pass --debconf-ok to ucf. The maintainer
    script should be fixed to not stop debconf before calling ucf,
    and pass it this parameter. For now, ucf will revert to using
    old-style, non-debconf prompting. Ugh!
    Please inform the package maintainer about this problem.
    sophocle:/usr/share/zabbix#
  • Signum
    • Sep 2009
    Hi, Razique...
    the message you are seeing is just a warning. You can safely ignore it. Please send us a bug report within Debian nonetheless so we can remove the annoying message. Just run this command in the shell...
    reportbug zabbix-frontend-php
    ...follow the questions and we will take of that bug.
    Regards
    Christoph
    (helping maintain the Zabbix packages in Debian)
    • Razique
      • Sep 2009
      • 19
      Hi, I ran the process and I submitted the bug
