Remote Node/Server setup
  • mrmurdock
    • Aug 2009
    • 85
    Hi, I have been able to get a remote zabbix (1.6.6) server setup and the node id changed to 1 and converted the database to be node id 1 (zabbix_server -n 1) and the conversion completed successfully. I have added the node id 1 to my local server (node id 0).
    Has this function been tested yet? The remote node is in Korea and attached via our internal WAN. What happens is when I connect from here in USA, I get "unable to select configuration". I know that my server here in usa, isnt receiving any feedback from the Korea server. Is there some other configuration I need to do to get this to work? I did setup the node values in the Administration --> Nodes section.
