I am not really sure I understand what you are asking here, but I will try to answer as best I can.
Zabbix keeps a history of your probes / items, for a preset period of time. Using this data it builds up trends to show you how the values of the probes / items have changed over time. By default, this information is only available through the graphing capabilities, however, as the data is stored in a regular database table it is available for external systems as well. As for validating it, you best bet is to monitor those items with Zabbix and with another package, for a period of time, and check for deviations.
Ok, for example: I have an item disk_used[c:] what I am monitoring to the 60 days, I configured Keep trends (in days) in the menu items for 30 days, as I I see the graph that anger to inform when the capacity to me of hd anger to finish probably?
or would have some link I to verify eats to create trend graph?
thanks
How should I proceed to do a tendency graphic?
An Example: I’m monitoring an item for about three months, (DISKUSE), and although I got the information and know that I can only do it in graph mode, could you please show me how to visualize when the disk capacity will be totally used in a tendency graph mode step-by-step? I already know that I can use this feature, but I’m still looking for it. Even so, could you give me some samples?
