Agent stops working
  • eppie
    • Jun 2009
    • 15
    Agent stops working
    Recently we have a problem with the agentd on one of our servers.
    The agentd stopts randomly with collecting data. In the logfile we see nothing strange.
    ps aux:
    zabbix   19124  0.0  0.0   2836   496 ?        SN   Nov17   0:00 /usr/local/sbin/zabbix_agentd
    zabbix   19125  0.0  0.0   2836   828 ?        SN   Nov17   0:49 /usr/local/sbin/zabbix_agentd
    zabbix   19126  0.0  0.0   2856   820 ?        SN   Nov17   0:51 /usr/local/sbin/zabbix_agentd
    Last lines of the logfile:
     19126:20091118:102016 Active check [custom.softraid.md3] is not supported. Disabled.
     19126:20091118:102016 Active check [system.cpu.util[,wait,avg1]] is not supported. Disabled.
    Error 6 initializing SQL*Plus
    Message file sp1<lang>.msb not found
    SP2-0750: You may need to set ORACLE_HOME to your Oracle software directory
     19126:20091118:102017 Active check [oracle[dbsize]] is not supported. Disabled.
     19126:20091118:102017 Active check [oracle[deadlocks]] is not supported. Disabled.
    [root@alliander log]# tail zabbix-agent/zabbix_agentd.log -f
    The errors in the log are caused by some scripts run by the agentd. (zabora)
    No messages in /var/log/dmesg etc.
    I already rised the debug level for the agent.
    Anybody an idea?
    Thx!
  • zabbix_zen
    • Jul 2009
    • 426
    How come nothing strange?
    Your agent isn't finding not even one of the Oracle Items your Template tells it to look.
    Do you have an Oracle DB in that host?
    Why don't you have set $ORACLE_HOME environmental variable?
    • eppie
      • Jun 2009
      • 15
      Thanks for your reply.
      Yes it has an oracle db but dbora is not yet properly configured indeed. But this was already
      the case for more then half year and we had no problems with that.
      But in case this can be the problem I've removed the custom parameters for the agent.
      I've raised the debug level and if it stops, it stops for exact one hour.
