Templates import problem
  • bigmac
    • Nov 2009
    • 21
    I use Zabbix 1.6.2 rpms from Mandriva 2009.1 repository.
    Here is the problem: when trying to create new template (there is practically no info in docs on the topic), i've found that "Add" action in Import is not available for templates. Than, i've created new template, new template.xml file on my computer, and tried to import it. Nothing happens. Zabbix web interface gives no positive or negative, nothing in log files. When i try to Export my templates, new template name is unavailable.
    So, my question is:
    What shall i do to create new template? How can i do it?
    And how can i see error messages?
    Just compiled newest 1.6.7, nothing changed. I am stuck. It seems to me, Edit action should be present in Zabbix GUI.
  • bigmac
    • Nov 2009
    • 21
    Happened to be PHP-XML problem. After php-xml installation import works.
    Too bad Apache/PHP part of installation is virtually not existent in the manual.
