Zabbix 1.8 MBstring?
  • Filter
    I'm trying a new install of zabbix 1.8, and during the pre requesite check, I'm getting a failure of: PHP MB String support
    I was also getting a failure of PHP MB String overload until I changed php.ini to include: mbstring.func_overload = 2
    I'm on CentOS 5.3, and in installed php-mbstring. Any suggestions on what I need to change to get zabbix to detect it?
    [[email protected] zabbix]# rpm -qa | grep php
    php-pdo-5.1.6-23.2.el5_3
    php-cli-5.1.6-23.2.el5_3
    php-mysql-5.1.6-23.2.el5_3
    php-gd-5.1.6-23.2.el5_3
    php-mbstring-5.1.6-23.2.el5_3
    php-common-5.1.6-23.2.el5_3
    php-5.1.6-23.2.el5_3
    php-bcmath-5.1.6-23.2.el5_3
    I'm having this same problem, also with CentOS. Everything tells me that mbstrings is installed and enabled, but the pre-req check won't clear me for takeoff.
      Same problem
        Its a problem with 2 functions, i'm comment them in:
        grep "mb_" zabbix/include/locales.inc.php function_exists('mb_strlen') &&
        function_exists('mb_strtoupper') &&
        function_exists('mb_strpos') &&
        function_exists('mb_substr'); # &&
        # function_exists('mb_stristr') &&
        # function_exists('mb_strstr');
        And zabbix setup was done without problem.
        I can't explain this - may be developers could?
          I commented out the entry in include/setup.inc.php which worked and got me past the installation screen.
            I confirm this problem. The problem exists only for PHP 5.0.x and 5.1.x. PHP 5.2 and later versions will work fine.
            Removing or commenting these two lines is absolutely correct workaround as these functions are not used anywhere in the front-end.
            Sorry for this problem.
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
              As documentation says PHP version 5.2 or later is required.
              How to install PHP 5.2.6 on Centos 5.3 ?
              [[email protected] ~]# rpm --import http://dev.centos.org/centos/RPM-GPG-KEY-CentOS-testing
              [[email protected] ~]# cd /etc/yum.repos.d
              [[email protected] ~]# wget http://dev.centos.org/centos/5/CentOS-Testing.repo
              [[email protected] ~]# yum --disablerepo=* --enablerepo=c5-testing update php
              http://www.zabbix.com/documentation/...n/requirements
                Zabbix 1.8 requires PHP 5.0 or later. The documentation is not correct, we will review and fix it shortly.
                Alexei Vladishev
                My Twitter
                  Yes, I'm use PHP 5.1.6.
                    ThankĀ“s
                    This how-to work for me.
                    PHP version: 5.2.9 Ok
                    PHP Memory limit: 128M Ok
                    PHP post max size: 16M Ok
                    PHP max execution time: 300 sec Ok
                    PHP Timezone: America/Bahia Ok
                    PHP Databases support: MySQL Ok
                    PHP BC math support: yes Ok
                    PHP MB string support: yes Ok
                    PHP MB string overload: yes Ok
                    PHP Sockets support yes Ok
                    GD Version: bundled (2.0.34 compatible) Ok
                    Image formats: PNG Ok
                    Ok
                      mbsring.func_overload
                      Web frontend installer checks "mbstring.func_overload 2" in php.ini file.
                      Then, strstr and stristr function is overloaded by mb_strstr and mb_stristr.
                      I checked source code.
                      - strstr function is not used
                      - stristr function is used in include/db.inc.php only
                      case 'ORACLE':
                              if(ocifetchinto($cursor, $row, (OCI_ASSOC+OCI_RETURN_NULLS))){
                                      $result = array();
                                      foreach($row as $key => $value){
                                              $field_type = strtolower(oci_field_type($cursor,$key));
                                              $value = (str_in_array($field_type,array('varchar','varchar2','blob','clob')) && is_null($value))?'':$value;
                                              if(is_object($value) && (stristr($field_type, 'lob') !== false)){
                                                      $value = $value->load();
                                              $result[strtolower($key)] = $value;
                              break;
                      mb_strstr and mb_stristr function is include PHP 5.2 or later.
                      http://php.net/manual/en/migration52.functions.php
                      Kodai Terashima
                      [URL="http://www.zabbix.jp"]ZABBIX-JP[/URL] - Japanese Zabbix community
                        PHP Memory limit: 256M Ok
                        PHP Timezone: Europe/Moscow Ok
                        PHP MB string overload: no Fail
                        Fail
                        Please correct all issues and press "Retry" button
                          php.ini
                            Worked for me too with Centos5.2/php-5.1.6-15.el5. Had to restart httpd before PHP MB string overload would pass.
                            PHP version: 5.1.6 Ok
                            PHP post max size: 128M Ok
                            PHP Timezone: Europe/London Ok
                            GD Version: bundled (2.0.28 compatible) Ok
                              i have solution
                              1. enter var/www/html/zabbix/include/
                              2. vi locales.inc.php
                              3. function_exists('mb_strlen') &&
                              ok...
                              Announcement
                              No announcement yet.
