1.8, bugs in while editing maps
  • gospodin.horoshiy
    • Sep 2008
    • 272
    Hi, I have two problems when trying create some new items on maps in 1.8
    1) If I create an object, select type - Host group - and then click 'select' - this will give an error instantly: ERROR: Zabbix has received an incorrect request
    2) When I try to place some russian literars into Label section of an item - I will have this kind of error: Get IMG: Element data not found. This will reset my background picture as well...
    P.S. Thnx for dragndrop!!!
    Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
    200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
  • richlv
    • Oct 2005
    • 3112
    1. is already on tracker, https://support.zabbix.com/browse/ZBX-1465
    2. hmm, as can be seen on zabbix.blip.tv, entering cyrillic works
    which db ? did you convert it to utf8 ?
    • gospodin.horoshiy
      • Sep 2008
      • 272
      mysql 5
      yes , I did
      • richlv
        • Oct 2005
        • 3112
        what element type are you using ?
        does it work with "image" type ?
        • gospodin.horoshiy
          • Sep 2008
          • 272
          It doesn't work with Image type as well as with others
          • richlv
            • Oct 2005
            • 3112
            hmm. which php version ? not sure as it works here - maybe report on the tracker
            • toxot
              • Jul 2009
              • 13
              I have a same problems. i try to use the svn://svn.zabbix.com/branches/dev/zbx-1465-hgmap, but it have no result maybe someone know how to fix this bug
              My frontend versions
              Apache 2.2.14_5
              php 5.2.11_1
