Graph Problem (gd is compiled in)
  • dmusser
    • Sep 2005
    This is a new install on RedHat AS, and I am not able to get any graphs to show up. What I get is the little red x like a graphic is not loaded.
    I checked the configure for the php, and it appears like I have loaded all of the things I have seen in this forum:
    './configure' 'i386-redhat-linux' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--prefix=/usr' '--with-config-file-path=/etc' '--enable-force-cgi-redirect' '--disable-debug' '--enable-pic' '--disable-rpath' '--enable-inline-optimization' '--with-bz2' '--with-curl' '--with-db3' '--with-dom=/usr' '--with-exec-dir=/usr/bin' '--with-freetype-dir=/usr' '--with-gd' '--with-gdbm' '--with-gettext' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-mm' '--with-openssl' '--with-png' '--with-pspell' '--with-regex=system' '--with-ttf' '--with-xml' '--with-expat-dir=/usr' '--with-zlib' '--with-layout=GNU' '--enable-bcmath' '--enable-debugger' '--enable-ftp' '--enable-magic-quotes' '--enable-safe-mode' '--enable-sockets' '--enable-sysvsem' '--enable-sysvshm' '--enable-track-vars' '--enable-trans-sid' '--enable-yp' '--enable-wddx' '--without-oci8' '--with-imap=shared' '--with-imap-ssl' '--with-kerberos=/usr/kerberos' '--with-ldap=shared,/usr' '--with-mysql=shared,/usr' '--with-pgsql=shared,/usr' '--with-unixODBC=shared,/usr' '--with-apxs=/usr/sbin/apxs'
    I am able to see items in the availability report, so it appears to be talking to the DB ok.
    I am using version 1.0. Any ideas?
