I'm having a problem getting the configure script to correctly find the curl libraries when I try to build static binaries.
The troublesome system is running RHEL5.3 and I've got the following curl packages installed:
# rpm -qa|grep curl
curl-devel-7.15.5-2.1.el5_3.5
curl-7.15.5-2.1.el5_3.5
Without --enable-static, the build finds all the dependencies and works as expected (awesome!). When I add --enable-static to the mix, the build craps out with the following:
checking for main in -lcurl... yes
checking whether libcurl is usable... no
configure: error: Curl library not found
Curl's libs appear to be in the correct place so I'm assuming this is some sort of bizarre interaction in the build script. This with Zabbix 1.8, but the problem also existed with the 1.6 tree that I downloaded a few days ago. Anyone have suggestions for a fix?
Best,
# rpm -qa|grep curl
Best,
