1.8 Graph Timezone problems
  • mucknet
    • Dec 2004
    • 59
    My servers are UTC, I configured php.ini for UTC timezone. However I'm located in PST, and my computer is set for PST (-8 hours)
    I'm running a fresh install of Zabbix 1.8
    When I click on a graph (simple or pre built graph), The graph shows me 8 hour old data (actually its showing me 7 hour old data? Maybe some problem with daylight savings?)...
    So if its 10.12.2009 (December 10th, 2009) 03:00 UTC, the default 1 hour graph view shows me 09.12.2009 (December 9th, 2009) 21:00. If I click on the "1hr" link, or drag the scroll bar all the way to the right -- or even just "click" it without draggin it. It will momentarily show me the correct data -- But then it will eventually revert back to the 7 or 8 hour old data.
    Any advice for me?
  • mucknet
    • Dec 2004
    • 59
    Also --
    Is it possible to change the date display to be Day.Month.Year, instead of Month.Day.Year? Thats really confusing for us americans My previous 1.4 installation defaulted to the american style.
