Can't editing or creat maps in 1.8
  • ew@senate.be
    • Mar 2009
    Hi to all!
    I've jut upgraded to version 1.8 and can't edit or create maps.
    Existing maps are displayed correctly but editing fails: the map is partially displayed (items but no links), its background isn't displayed, list of items of links is not displayed.
    I'm on a Centos 5.3 box, with php 5.1.6 and Apache 2.2.3 .
    Error message in web server log is:
    [Thu Dec 10 15:25:21 2009] [error] [client 172.16.1.249] PHP Warning: require_once(include/classes/class.fichierconf.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /var/www/html/zabbix/include/config.inc.php on line 74, referer: http://netmgt/zabbix/sysmap.php?sysm...2ca1036f580e9a
    [Thu Dec 10 15:25:21 2009] [error] [client 172.16.1.249] PHP Fatal error: require_once() [<a href='function.require'>function.require</a>]: Failed opening required 'include/classes/class.fichierconf.php' (include_path='.:/usr/share/pear:/usr/share/php') in /var/www/html/zabbix/include/config.inc.php on line 74, referer: http://netmgt/zabbix/sysmap.php?sysm...2ca1036f580e9a
    Any and all help will greatly be appreciated.
    Thanks,
    Emmanuel
  • ew@senate.be
    • Mar 2009
    problem solved
    ok, problem solved: clearing the firefox cache did the trick. However I'm baffled by the fact that something in the cache made php try to include a non existant php file on the server side ...
    • Palmertree
      • Sep 2005
      • 746
      I do not see the class include/classes/class.fichierconf.php in my version of 1.8. Not sure what that class does.
      • ew@senate.be
        • Mar 2009
        I know.
        The file is supposed to be included by a statement on line 74 of file /var/www/html/zabbix/include/config.inc.php, and that statement builds the name of the file to be included dynamically.
        As I said, I'm still wondering how that file name got generated ...
        Could it have something to do with the db not being converted to UTF-8? I only did that after I ran into the above trouble, and I took a closer look at the patches directory.
        • richlv
          • Oct 2005
          • 3112
          utf8 conversion should not have anything to do with this.
