Zabbix 1.8 Host / HostGroups / UserGroup Problem
  • deejay24
    • Dec 2009
    i have the following problem, maybe a bug:
    - Install Zabbix from scratch
    - create a host & hostgroup (mytest, mytest) with user admin
    - create a user called testa
    - create a usergrp called testuser
    - put hostgroup in usergroup (read/write)
    - login with user testa
    => Hostgrp mytest is empty
    therefor map have a problem with the right as well
  • richlv
    • Oct 2005
    • 3112
    most likely https://support.zabbix.com/browse/ZBX-1409
    • mbrijun
      • Mar 2006
      • 63
      Hi RichLV,
      I think the ZBX-1409 does not apply here. I am also unable to see any hosts, but instead of an error message I am getting a JSP error on IE:
      Line: 15
      Char: 1
      Error: Ojbect expected
      Code: 0
      Martin
      • richlv
        • Oct 2005
        • 3112
        js error, i suppose. have you tried with another browser ?
        • mbrijun
          • Mar 2006
          • 63
          yes, Firefox just gives a blank window when I request a list of hosts. IE at least gives me a JS error in the lower left hand corner.
          • richlv
            • Oct 2005
            • 3112
            could you try with frontend from svn, just to make sure the issue is still there ?
            • mbrijun
              • Mar 2006
              • 63
              Hi Rich,
              I have tried to install the frontend from CVS this morning, but no luck so far. Once I check out the frontend from CVS, it seems to contain fewer files/dirs than the official frontend. This is the command I am using:
              cvs -z3 -dserver:[email protected]:/cvsroot/zabbix co -P zabbix/frontends/php
              If I try to run this incomplete frontend, it gives me the following error message:
              Error connecting to database [Access denied for user 'apache'@'localhost' (using password: NO)]
              I suspect some part of the config is missing. Please could you give me a few hints on how to proceed. Also, I am using the CentOS 5.4 with php 5.1.6 so I think I will be affected by the MBString problem.
              Thanks.
              • richlv
                • Oct 2005
                • 3112
                that's some awfully ancient zabbix repository... current repository can be found at svn://svn.zabbix.com
                maybe http://www.zabbix.com/wiki/contrib/getting_source helps some
                after checking out the new frontend i'd suggest just copying over the frontend config file from the existing one.
                mbstring would only affect installer in your case, although which db are you using ?
                • mbrijun
                  • Mar 2006
                  • 63
                  Hi Rich,
                  that CVS repo is advertised on the following page: http://sourceforge.net/projects/zabbix/develop
                  While trying to get the trunk from svn, I am getting an error message. Is it just me? My PC does not have any problems accessing any other hosts on the internet.
                  # svn co svn://svn.zabbix.com/trunk
                  svn: Can't connect to host 'svn.zabbix.com': Connection timed out
                  Thanks,
                  Martin
                  • mbrijun
                    • Mar 2006
                    • 63
                    Is SVN repository down?
                    I am trying to follow richlv's suggestion to see if the php frontend from SVN resolves an issue with hosts.php (no content is displayed). Unfortunatelly, I have been unable to reach the repository since Friday. It simply times out.
                    I am trying the following command:
                    Please tell me if I am doing something wrong or is the host simply down?
                    Thank you.
                    • richlv
                      • Oct 2005
                      • 3112
                      does it work for you now ? can you access any other svn repository using svn port (not http[s]) ?
                      • mbrijun
                        • Mar 2006
                        • 63
                        Hi Rich,
                        thanks for being patient with me. Your post about http/svn made me understood that I am having a firewall restriction on the SVN port.
                        Having downloaded the 1.9 frontend I can see that the hosts.php problem is still there. I am getting a blank screen.
                        What is the best way from here? Thanks.
                        • richlv
                          • Oct 2005
                          • 3112
                          1. check apache/php logs;
                          2. grab exact error with either opera error console or firebug extension for firefox;
                          3. try with latest versions of firefox, opera
                          if you don't see any errors that hint at what the problem is, report on the tracker, including all the above information as well.
                          • mbrijun
                            • Mar 2006
                            • 63
                            Hi Rich,
                            The apache log file has provided me with a clue. I believe that the problem was caused by the insufficient memory setting in php.ini. While upgrading from zabbix 1.6 to 1.8, I did not change the memory_limit from 16M to 256M. As I am running CentOS 5.4 I had to manually configure the zabbix.conf.php and that way the parameters were not checked by the install progam.
                            Thank you for all your help, much appreciated.
