Disable items in Zabbix 1.8
  • jansonz
    • 53
    Is it possible to disable item in host which is linked to some Template?? In older Zabbix version this was possible, but in 1.8 not
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It is available in the list of items. Why do you think it is not there?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jansonz
      • 53
      It is there, but if I try to disable item which is linked to template nothing happens - it stays enabled. If I create new item to this host and try to disable it there is no problem. So I think there is problem only with items which is linked to templates.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        We are aware of this problem: https://support.zabbix.com/browse/ZBX-1528
        Alexei Vladishev
        My Twitter
        • richlv
          • Oct 2005
          • 3112
          that doesn't seem to be a correct link
          having said that, i can't reproduce the problem - items from templates can be enabled/disabled downstream. what's the exact configuration and steps that result in error/problem ?
