I get repetative notifications over SMS
  • rualark
    • Sep 2005
    In the "Alerts" section there is one notification sent when trigger fires, but i get 2 same messages on phone.
    What is "Delay between messages (in sec)" and can it help my problem?
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    That is what the delay is meant to solve. By default the delay is set to 30 seconds, which means that as long as the trigger is true, you will get one alert every 30 seconds. I recommend setting this no lower than 300 seconds.
    The second issue that you might be seeing is a problem with the way the system processes multiple medias. If you have two or more media types configured, the system appears to fire them all off one time for each type of media you have defined. For example, if you have email and a script defined, both will fire twice per delay period. If you have email, and two scripts defined, each will fire three times per delay period.
    Unofficial Zabbix Developer
