Has the vulnerability described in ZBX-1030 been addressed in 1.6.8? Or, is it only fixed in 1.8?
ZBX-1030 for 1.6.x?
It is only fixed in 1.8. The problem is that the fix requires changes in communication protocol between the front-end and the server. This would break compatibility with earlier versions of 1.6.x. -
Actually it WILL be integrated into 1.6.x!
The integration is quite straight-forward, the only drawback is that once it is fixed one should use latest revisions of both front-end and Zabbix server, which is probably what most users already do.Comment
Sounds good. Looking forward to the fix.Comment
