Unable to Import Templates from Zabbix 1.6.6 to Zabbix 1.8
  • RonikBeast
    • Dec 2009
    Hi to all.
    I am triying to import all the configuration from my Zabbix 1.6.6 to the new version 1.8.
    First, in the 1.6.6 version make a export only of the two new templates that i was configured. One had 30 items and 14 triggers, the second only had 10 items.
    Save the export file in local hard disk.
    When i connect to the 1.8 version, select the import option, all the checkboxes are actives. Push the import botton all always the same error:
    History: Dashboard » Host groups » Dashboard » Host groups » Export/Import
    Fatal error: Call to undefined method CTemplate::add() in /home/zabbix/public_html/include/export.inc.php on line 585
    I'm tried to deselect some checkboxes, but always the same error.
    Can someone help me?
    Thanks,
    Ronik
  • sersad
    • May 2009
    • 518
    • RonikBeast
      • Dec 2009
      Hi Sersad:
      Thanks a lot!!! The solution Works Fine.
      Greets,
      Ronik
