log of actions
  • sean
    • Mar 2008
    • 28
    log of actions
    Is there a log of actions/operations carried out? Perhaps in an SQL table somewhere, browsing the history tables did not turn up what I needed..
    I'm trying to troubleshoot an AlertScript called for a media type.. no trace of it in the zabbix log file with Debug level=3.
  • richlv
    • Oct 2005
    • 3112
    administration -> audit -> actions
    • sean
      • Mar 2008
      • 28
      Thanks that does help. Its should outgoing emails.
      But when I configure an Operation of sedning a message to a user configured to run a Script media type, no entry appears in that log.
      • richlv
        • Oct 2005
        • 3112
        if operation is executed but not logged there, please report it on the tracker as a bug, thanks
        • sean
          • Mar 2008
          • 28
          I have it working now, there were problems in my script.
          Zabbix does not display or log the stdout or stderr from the script, which makes debugging harder.
          FYi I used the following test script to help me troubleshoot, this may help others:
          #!/bin/bash
          f=/tmp/zabbix_testscript.log
          echo "__________" >> $f
          echo `date` >> $f
          for i in "$@"; do
          echo "Parameter:$i" >> $f
          done
