Hello Alexei,
I'm using 1.1beta1. When browsing the graph or screen time selection, I'm noticing that the field "period" doesn't stay on the selection.
Example:
graph is 1 hour period, I select 1 week, then I increase 1 week and the graph shows correctly 2 weeks. Note that the field "period" goes back to 1h so the next time you increase or decrease the period, it refers to 1h not to the week selected before.
Second thing:
every time you change anything on the graph period or range, host and item informations are lost. This is very annoying. Can you please fix it?
Thanks and regards.
Example:
Second thing:
Thanks and regards.
