Cannot add macro to host template
  • nmail_uk
    • May 2009
    • 65
    I'm trying to add a macro to my generic host template in 1.8 for the SSH port.
    Whenever I try to add the macro to the template I just get the error, "Wrong macro : SSHPORT"
    What does this mean? Can I not add a macro to a template? The manual seems to hint that it's OK:
    In other words, if a macro does not exist for a host, Zabbix will try to find it in host templates.
    I also get the same error when trying to add a macro to a host.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please use {$SSHPORT} instead of SSHPORT. Note that the special syntax has to be used for all user-defined macros.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • nmail_uk
      • May 2009
      • 65
      Thanks Alexei,
      I thought it was just when using the macros that the syntax had to be used.
      Cheers,
      Andy
