Recovery messages doesn't work in 1.8
  • ProTON
    • Oct 2005
    • 77
    Recovery messages doesn't work in 1.8 completely. No matter what I set I always get only original action message. Any confirmations?
    UPDATE: seems like I haven't read manual carefully. Setting additional condition of Trigger value = PROBLEM helped. However there are some inconsistencies between "AND" and "AND/OR" calculation type. For example I have Trigger = mytrigger and Trigger value = PROBLEM conditions. Action has recovery messages set. With "AND/OR" calculation type I recieve 5 recovery messages, but with "AND" only 1.
  • Palmertree
    • Sep 2005
    • 746
    I have found that the "escalations" table needs to be truncated when things go crazy... Make sure you make a backup first...
    • ProTON
      • Oct 2005
      • 77
      I'm not using escalations and escalation table is empty.
      Also this doesn't explain who AND and AND/OR calculation type differs.
      • Zaniwoop
        • Jan 2010
        • 232
        I have the same problem.
        To test it, I put "Trigger message" and "Recovery message" in message body of the two messages.
        I get "Trigger Message" both times.
        I am using Zabbix 1.8.1
        In 1.6.x this worked fine.
        • r0k5t4r
          • Jun 2009
          • 91
          Same Problem here. Version 1.83. Has this been fixed?
          • ProTON
            • Oct 2005
            • 77
            It is fixed in 1.8.2. See: https://support.zabbix.com/browse/ZBX-2001
            • zalex_ua
              • Oct 2009
              • 1286
              Maybe that's your case
              Vote if you do not want this happened on other beginners.
