Trigger stopped working after 1.6->1.8 upgrade.
  • Firm
    • Dec 2009
    • 342
    I use 'icmpping' from 'Simple checks' to be aware of host availability every 5 seconds. Also I have trigger '{Isp:icmpping.count(30,1)}<1' which sends alert if consecutive pings within 30 last seconds return 0 state. In 1.6 it worked. In 1.8 - not. Any ideas?
  • RonikBeast
    • Dec 2009
    FPING missing?
    This happened to me the same, but looking at the cause of the error, the description of the item that I saw marked "Not supported" and that was because the error icon.
    Putting the error over the icon I saw that told me I was missing the command "fping". The error was this:
    / usr / sbin / fping: [2] No such file or directory
    See if you feel the same, at least in the server version of Ubuntu do not install the program by default, you have to install a post and make sure the program path is correct, or modify the file Zabbix configuration to tell the new location.
    • Firm
      • Dec 2009
      • 342
      Well, data get collected as usual (0 - down, 1 - up). But trigger stopped to react. I've re-created it - no luck. Think about changing it to {Isp:icmpping.count(#5,1)}<1 (last 5 values are zeroes). Will check if it helps.
      • Firm
        • Dec 2009
        • 342
        Good news. Changing trigger from '{Isp:icmpping.count(30,1)}<1' to '{Isp:icmpping.count(#5,1)}<1' helped.
        • cionfolinet
          • Jul 2009
          I have the same problem.
          My trigger is {Isp:icmpping.count(400,0)}>6 (Number of retrived values 0 for period of time 400 > 6).
          In 1.6.7 works fine.
          Now if i change my trigger in {Isp:icmpping.count(#5,1)}<1 works.
          I think this is a bug.
          • zabbix_zen
            • Jul 2009
            • 426
            I'll only update to 1.8 next week but this looks like a bug indeed.
            Can you file a bug in : https://support.zabbix.com/browse/ZBX?
            • cionfolinet
              • Jul 2009
              Of course!
              #ZBX-1730
              • Spectroman
                • Sep 2008
                • 17
                fping option failure
                After updating from Zabbix 1.6.6 -> 1.8, fping failed.
                Raising the debug level on the log I received the following:
                32282:20100111:152641.336 /usr/sbin/fping -q -C3 -S10.3.0.151 2>&1 </tmp/zabbix_server_32282.pinger
                32282:20100111:152641.343 Update IP [/usr/sbin/fping: invalid option -- S]
                32282:20100111:152641.343 Update IP [Usage: /usr/sbin/fping [options] [targets...]]
                32282:20100111:152641.344 Update IP [ (ex. /usr/sbin/fping -g 192.168.1.0 192.168.1.255 or /usr/sbin/fping -g 192.168.1.0/24)]
                Is that my fping is too old (it is the latest), or the option is not supposed to be there?
                Fping information follows:
                xx151:/data/install/sources # fping -v
                fping: Version 2.4b2_to $Date: 2001/01/25 11:25:04 $
                fping: comments to [email protected]
                xx151:/data/install/sources # fping -h
                Usage: fping [options] [targets...]
                -a show targets that are alive
                -A show targets by address
                -b n amount of ping data to send, in bytes (default 68)
                -B f set exponential backoff factor to f
                -c n count of pings to send to each target (default 1)
                -C n same as -c, report results in verbose format
                -e show elapsed time on return packets
                -f file read list of targets from a file ( - means stdin) (only if no -g specified)
                -g generate target list (only if no -f specified)
                (specify the start and end IP in the target list, or supply a IP netmask)
                (ex. fping -g 192.168.1.0 192.168.1.255 or fping -g 192.168.1.0/24)
                -i n interval between sending ping packets (in millisec) (default 25)
                -l loop sending pings forever
                -m ping multiple interfaces on target host
                -n show targets by name (-d is equivalent)
                -p n interval between ping packets to one target (in millisec)
                (in looping and counting modes, default 1000)
                -q quiet (don't show per-target/per-ping results)
                -Q n same as -q, but show summary every n seconds
                -r n number of retries (default 3)
                -s print final stats
                -t n individual target initial timeout (in millisec) (default 500)
                -u show targets that are unreachable
                -v show version
                targets list of targets to check (if no -f specified)
                ** notice no such option -S **
                Using the fping from original source: http://fping.sourceforge.net/
                ** solution follows **
                • Spectroman
                  • Sep 2008
                  • 17
                  fping option failure - ** solution **
                  Something strange has happened after I did the Zabbix update between 1.6.6 -> 1.8, the problem that I could figure out properly now is:
                  - During the change of versions, I noticed some new options on the new zabbix_server.conf , so I opt to use the new version, and I configured the whole new file accordingly the older conf options and using some new ones;
                  - Among these options I enabled : SourceIP - source ip address for outgoing connections;
                  - When I put the server up, he was failing in all the ICMP tests, and raising the debug level (to 4) I could see an error on the fping usage, something very weird;
                  - After investigating a little further, I figure out that, even if I fix the exceeding option (-S) for fping, in the source code of [ /zabbix-1.8/src/libs/zbxicmpping/icmpping.c -- line 58 ] which corresponds to the configuration option of "Source IP", it does not work at all, any of the ICMP work -- probably because this options affect more lines of code and actions of the system;
                  - Later on, disabling the option Source IP from the configuration file, almost magically, everything went back to normal.
                  I believe I stumble in a couple of bugs, isn't?
                  - I also noticed that with the SourceIP enabled, he conflicts with the zabbix_agent port, if both are configured with the defaults.
                  I hope this could help others to figure out this erratic behavior with fping / source ip option.
                  • davidpe
                    • Mar 2007
                    • 18
                    Using version 1.8.1, I removed lines 57 and 58 in that file, recompiled, and has been working just fine.
