Hi to all.
I have created a series of screens in the new version 1.8, copied from the ones I had in version 1.6.6.
When you in the 1.6.6 version reduces a graph, the graph is reduced and the letters (title and legend) that accompanies it also do the same scale.
In version 1.8 when you insert a graph on a screen, draw the graph and the accompanying letters, and even then you reduce the size of the chart, the letters remain always the same size, without having seen any option for these letters reduced to the same extent as the graph, as was the case in the previous version.
I also noticed that he had put measures in version 1.6.6 not in line with moves in version 1.8, if I put the same values in version 1.8 that I had made in version 1.6.6 the total size of the graph is significantly larger, but this may be due to the problem of the letters mentioned above.
Can anyone tell me if it's a bug, or do I have any option to correct this?
Thank you,
Ronik
Thank you,
Ronik
