Just to second UnterGeek on this one, we're seeing the exact same problem.
I'm running on AIX 5.3 with Zabbix 1.8 and Oracle 10.2 backend (full enterprise license). We compiled against the lib32 OCI libraries just fine.
Running Zabbix 1.6.8 with Oracle 10.2 and the libsqlora8 performed just fine. Running 1.8 on the same server with the same database has issues.
Right now I have 900 items queued up across 5 different item types and our stats are very low...
I can provide any info needed. I'm sure it's a config issue somewhere. Troubleshooting 101 says you look for what's changed. Server and Database are exactly the same as they used to be. Zabbix and Oracle connection is different.
Number of hosts (monitored/not monitored/templates) 106 42 / 14 / 50 Number of items (monitored/disabled/not supported) 1579 877 / 617 / 85 Number of triggers (enabled/disabled)[true/unknown/false] 355 355 / 0 [1 / 116 / 238] Number of users (online) 8 2 Required server performance, new values per second 17.5097222222 -
