Zabbix web interface issue with Chrome
As in a show process list or would you like me to see if I can dump the sql queries themselves to disk?RHCE, author of zbxapi
Also what about the PHP frontend? Is there a facility for enabeling debug logs? The new 1.8 frontend debug method does not work as the page hangs half way through.RHCE, author of zbxapi
Same issue here
I am seeing the same problem with multiple browsers. This is my current configuration:
Ubuntu 9.10
MySQL 5.1.37 x86_64 (InnoDB)
DM enabled, 1 master node, 4 child nodes, 1 proxy per node (for now)
If I can help by submitting any logs let me know. Here is my processlist output when the frontend is hung:
mysql> show processlist;
| Id | User | Host | db | Command | Time | State | Info |
| 38 | zabbix | zabbix-frontend:52651 | zabbix_main | Query | 1 | freeing items | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 39 | zabbix | zabbix-frontend:52652 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 40 | zabbix | zabbix-frontend:52653 | zabbix_main | Query | 2 | freeing items | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 41 | zabbix | zabbix-frontend:52654 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 42 | zabbix | zabbix-frontend:52655 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 43 | zabbix | zabbix-frontend:52656 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 44 | zabbix | zabbix-frontend:52657 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 45 | zabbix | zabbix-frontend:42236 | zabbix_main | Query | 0 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 48 | zabbix | zabbix-frontend:42088 | zabbix_main | Query | 1 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=1 AND table_name='profiles' AND field_name='profileid' |
| 49 | root | localhost | NULL | Query | 0 | NULL | show processlist |
+----+--------+------------------------------------------------+-------------+---------+------+---------------+----------------------------------------------------------------------------------------------------+Comment
I see the same queries as cronuscronus when this shows up on our servers. Those queries are cycling through very quickly as well. Continuing to send the 'show full processlist' command continues to show the same query executing over and over.
Server version: 5.1.41-community-log MySQL Community Server (GPL)
InnoDB with file-per-table.
DM enabled, 1 master node, no active child nodes, 8 proxies
592 hosts, 6320 items, 3881 triggersComment
Thank you all for the additional details! It really helps.Comment
Not a problem. We'd like to see the problem solved so let us know what else you need. This seems to only happen on the dashboard. I can cruise around triggers etc... until I'm blue in the face with no problem (all nodes selected).
If it counts for anything I have NoHistorySend=1 and NoEventSend=0 on all nodes.
Thanks,
AaronComment
It looks like this is not a new error:Not a problem. We'd like to see the problem solved so let us know what else you need. This seems to only happen on the dashboard. I can cruise around triggers etc... until I'm blue in the face with no problem (all nodes selected).
Thanks,
Aaron
Unfortunately the lock and table format changes haven't worked for me
I just did a fresh install, enabled the zabbix server, opened a new tab and went to "latest data", then opened another tab and pulled up the screens page. The screens page is frozen, I can navigate the latest data page but when I go to click on a graph, no go. Restarting apache is the only fix. :-(
What's interesting however is after reset I can view the screens page just fine. The last time I was able to duplicate this was with a fresh 1.8.1 install.
Here's what I'm seeing:
I watch the info col go from "updating" to "freeing items" but never go away.Code:Every 5.0s: echo "show processlist;" | mysql | grep -v Sleep Tue Feb 9 01:57:07 2010 Id User Host db Command Time State Info 214 root localhost zabbix Query 1 freeing items UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' 215 root localhost zabbix Query 0 Updating UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' 220 root localhost zabbix Query 1 Updating UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' 239 root localhost zabbix Query 0 Updating UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' 344 root localhost NULL Query 0 NULL show processlist
Again!
I just had it again on my work server. While showing the CEO no less! quite embarrassing.
We were navigating around, going to latest data, then to configuration, then to screens, then pulled up another screen... frozen. Dashboard still worked, but at that point we walked away from the demo.
Mysql still shows the same problem as before.
Code:| 129013 | zabbix | localhost | zabbix | Query | 0 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' | | 129016 | zabbix | localhost | zabbix | Query | 0 | freeing items | UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' | | 129036 | zabbix | localhost | zabbix | Query | 0 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' | | 129040 | zabbix | localhost | zabbix | Query | 0 | Updating | UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profileid' |
The common thread for my experiencing this bug seems to be "new". When I do a new install I have a problem, when I add a new user I see it. I'm wondering if there is an issue with the initial setup of a user in the ids table.RHCE, author of zbxapi
I moved the database to a more powerful server and then changed the db engine on the IDS table to MYISAM and the problem has gone away. Apparently InnoDB requires a lot of horsepower especially when executing so many updates.Comment
Try this patch, and report if it helps. Patch is against pre 1.8.2 (but may work on 1.8.1 didn't checked)Attached FilesZabbix | ex GUI developerComment
Excellent, the patch worked for me, thank you! Couldn't patch with patch, though, had to manually add/delete/modify the lines, but now I don't get the database pounding I once had.
Thanks!
Also, here's a patch for the changes I made. It appears the only differences were cosmetic, but it might help someone with 1.8.1 that needs this fix.
-RonAttached FilesComment
