Solaris 10, MySQL 5.1, Zabbix 1.8, today's frontend (revision 8986).
I have recreated everything and it still does this so I know it's not just me. I have a pile of templates, discovery rules and actions and for some strange reason SOME of my triggers get duplicated when I use the discovery action "link to template"
The irritating thing is that it's not every trigger, just some of them. The ones that are duplicated are duplicated on EVERY host the template is linked to. It's multiple templates that do this, too.
Further investigation reveals the following:
- If I use the host page to unlink and clear, then relink the template there are no duplicates.
- If I use the template page to unlink and relink I it sometimes comes back clean, but other times I get orphaned duplicate triggers not associated with the template which I can then delete.
- There's a bug in the link to template dialog in the host screen in that EVERY template that's not already assigned (which means they're greyed out) is pre-selected. There is no select all or deselect all in the pop-up. This is very annyoing.
