Zabbix agent 1.8 solaris 10 - run problem
  • ufocek
    • Aug 2006
    • 161
    When I log into the system as user zabbix and run ./zabbix_agentd I get this error:
    ld.so.1: zabbix_agentd: fatal: libiconv.so.2: open failed: No such file or directory
    Killed
    This same error I have if I run: svcsadm enable zabbix-agent
    svcadm enable zabbix-agent
    bash-3.00# tail -f /var/svc/log/application-zabbix-agent\:default.log
    [ Jan  9 13:52:00 Enabled. ]
    [ Jan  9 13:52:00 Executing start method ("/usr/local/zabbix/sbin/zabbix_agentd") ]
    [ Jan  9 13:52:00 Method "start" failed due to signal KILL ]
    ls -lh /usr/local/lib/libiconv.so.2
    lrwxrwxrwx 1 root root 17 Oct 31 2008 /usr/local/lib/libiconv.so.2 -> libiconv.so.2.4.0
    Any ideas?
  • Tenzer
    • Nov 2007
    • 316
    Try to run 'ldd ./zabbix_agentd', this will show all libraries the program needs, and if any of them can't be found.
