Zabbix sender hostname domain ?
  • system
    • Aug 2009
    Zabbix sender fails when used with uname -n:
    [root@host bin]# /usr/local/sbin/zabbix_sender -s `uname -n` -z zbxserver -k mykey -o `date +%s`
    Info from server: Failed 1
    Because uname returns hostname + domain :
    [root@host bin]# uname -n
    myhost.mydomain.fr
    It works when specifying hostname without domain manually :
    [root@host bin]# /usr/local/sbin/zabbix_sender -s myhost -z zbxserver -k mykey -o `date +%s`
    Info from server: "Processed 1
    In opposition to what the doc states, it does not work with IP :
    [root@host bin]# /usr/local/sbin/zabbix_sender -s 10.0.13.19 -z zbxserver -k mykey -o `date +%s`
    Info from server: "Failed 1
    In Zabbix web interface, in hosts configuration, I tried to specify the domain, either in DNS, or in Name field. None solved the problem.
    Do you have any idea ? Is it wrong to use uname in zabbix sender commands ? How would you make your scripts generic then ?
  • tighep
    • Dec 2007
    • 124
    instead of uname -n use hostname -s
    • system
      • Aug 2009
      I thought of using hostname, but then I realized I could have several domains for one hostname...
      webmail.mydomain.fr
      webmail.myotherdomain.fr
      Will Zabbix be able to distinguish where it comes from ?
      • tighep
        • Dec 2007
        • 124
        The -s flag should match what Zabbix knows the system as, in my case these are short hostnames. In your case it appears that a fully qualified name is most appropriate, but it appears that Zabbix does not know your systems that way?
        • system
          • Aug 2009
          Thanks for your answers.
          I'll make it with hostname -s, should be enough.
