Zabbix 1.8 agent troubles. (using dashes in command arguments)
  • traq911
    • May 2005
    • 17
    Hi there.
    I've recently upgraded to Zabbix 1.8 (love the new features!)
    The agent, however, seems to fail with ZBX_NOTSUPPORTED when trying to execute a custom user command containing dashes '-' within the passed arguments.
    For example my user command:
    UserParameter=zstat[*],/opt/zabbix/bin/zstat.sh "$1" "$2" "$3"
    When called by:
    zstat[zpool,pool-0,capacity]
    - or -
    zstat[daemon,/opt/syslog-ng/sbin/syslog-ng,root]
    fails with ZBX_NOTSUPPORTED.
  • fips
    • Sep 2005
    • 38
    Same problem
    I have the same problem with user items.
    In 1.8 is a restriction of allowed characters in parameters:
    error: Special characters '\'"`*?[-]{}~$!&;()<>|#@' are not allowed in the parameters
    I loose a lot of flexibility for my user items, if I can not use this characters!
    I like to vote to get them back!
    • Palmertree
      • Sep 2005
      • 746
      Originally posted by traq911
      Hi there.
      When called by:
      - or -
      To remove the dash restriction here is a patch:
      diff -ruN /root/zabbix-original/src/libs/zbxsysinfo/sysinfo.c /root/zabbix/src/libs/zbxsysinfo/sysinfo.c
      --- /root/zabbix-original/src/libs/zbxsysinfo/sysinfo.c    2010-01-18 21:16:48.000000000 -0500
      +++ /root/zabbix/src/libs/zbxsysinfo/sysinfo.c    2010-01-18 21:16:55.000000000 -0500
      @@ -341,7 +341,7 @@
           char buf[MAX_STRING_LEN];
           char command[MAX_STRING_LEN];
           register char *pl, *pr;
      -    const char    suppressed_chars[] = "\\'\"`*?[-]{}~$!&;()<>|#@\0", *c;
      +    const char    suppressed_chars[] = "\\'\"`*?[]{}~$!&;()<>|#@\0", *c;
           assert(out);
      • gpmidi
        • Aug 2009
        • 62
        This is a problem for me too
        This is annoying me too. Will this be fixed in a later release?
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Yes, it will be fixed!
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • gpmidi
            • Aug 2009
            • 62
            Excellent
            Excellent. I'm happy to hear it.
            • ad@kbc-clearing.com
              • Sep 2005
              • 77
              In zabbix agent 1.6, the backslash (\) was no problem in a user parameter.
              In zabbix agent 1.8, it has become unsupported. Why ?
              Since we use a lot of backslashes in userparams, we have to stick with the 1.6 agent
              Will this be fixed ?
              • vinny
                • Jan 2008
                • 145
                Hi Alexei,
                Is it already fixed ?
                It does not seem to be done with the revision 10048...
                And what about the forbidden pipe "|" too ?
                It is very useful on nux & windows....
                In the documentation of Win agent, it is said :
                User-defined parameter to monitor. There can be several user-defined parameters. Value has form <key>,<shell command>. Do not use spaces around pipe ('|') characters! Example:UserParameter=test,echo 1
                thx,
                vinny
                Zabbix 1.8.3, 1200+ Hosts, 40 000+ Items...zabbix's everywhere
                • vinny
                  • Jan 2008
                  • 145
                  Has this problem been fixed in the dev version ?
                  This is very penalizing...
                  vinny
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    vinny
                    We introduced new parameter for Zabbix Agent: UnsafeUserParameters. Set it to 1 in order to allow any characters you want.
                    Alexei Vladishev
                    My Twitter
                    • vinny
                      • Jan 2008
                      • 145
                      Great Alexei,
                      thx for the tips !
                      vinny
