I've seen it in the forums before but can't find it for the life of me. What is the command you can use with the zabbix agent to show you what the agent will and will not monitor on a given system?
So for example once I have the agent running on my linux system I can type this command in and it will return with a list of what it will and will not monitor.
Thank you
Thank you
