ZabbixW32 Agent service terminated unexpectedly
  • timeless
    • Oct 2005
    I have installed Windows Agent on many windows servers, but only two of them (win2000) are having the touble.
    I have no problem with installation or start the service from the command line. But if I checked the process, the Agent wasn't running at all.
    Then I issued the ZabbixW32.exe stop, it said the service wasn't running.
    I checked the event log and it showed "The ZabbixW32 Agent service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds. No action." If I manually start the service, it will pop out saying "Could not start the ZabbixW32 Agent service on Local computer. Error: 1067: The process terminated unexpectedly."
    Is anyone having the same problem? What's causing it?
    Please help! Thanks!
  • timeless
    • Oct 2005
    Re: ZabbixW32 Agent service terminated unexpextedly
    I think I found the problem is on the client. The port 10000 that zabbix listens was being used by other process. After I changed to use the different port, it seems start working.
    • timeless
      • Oct 2005
      the specified object is not found on the system??
      This server is odd...
      This time I got unable to add performance counter
      "\unknownPerformanceCounter(_Total)\unknownperform ancecounter" to query:
      The specified object is not found on the system.
      Is anyone seeing this error before?
      Thanks in advance!
      • cybaspace
        • Jul 2005
        • 43
        We had the same thing over here and it seemed that it happened because of the length of the servername. First we had a NEXDOUBLER_DL380 server, and we weren't able to start the service. After we renamed the server to NXDBLR it worked fine... Strange but true...
        • timeless
          • Oct 2005
          Thanks, cybaspace!
          unfortunately, I can not change the server name.
          Is there a way to use the alias name in the agent.conf??
          Or have it in the hosts file??
