Zabbix 1.8 Ubuntu 9.10 probléme MB string support Fail
  • mika2006
    • May 2007
    • 15
    Hello i m trying to install the lat zabbix and i have a problem on 3. Check of pre-requisites
    i don't know how pass the problem :
    PHP Code:
    PHP version:  5.2.10-2ubuntu6.4 Ok
    PHP Memory limit
    : 256M Ok
    PHP post max size
    : 16M Ok
    PHP max execution time
    : 300 sec Ok
    PHP Timezone
    : Europe/Paris Ok
    PHP Databases support
    :  MySQL Ok
    PHP BC math support
    : yes Ok
    PHP MB string support
    : yes Ok
    PHP MB string overload
    : no Fail
    PHP Sockets support yes Ok
    GD Version
    : 2.0 or higher Ok
    Image formats
    : PNG Ok
    Fail
    Maybe i need update php, but how do this on ubuntu 9.10 please?
  • modest
    • Dec 2009
    • 40
    You should check this topic, it might contain solution for your problem:
    • Firm
      • Dec 2009
      • 342
      mika2006,
      Check web server error logfile for more information.
      • mika2006
        • May 2007
        • 15
        i make this :
        sudo nano /etc/php5/apache2/php.ini
        i found
        PHP Code:
        mbstring.func_overload
        and i write the value 2.
        • akmalsiddiqui
          • Dec 2011
          The solution to that is following
          mbstring.func_overload = 2
