Hi all,
I'm upgrading from 1.6.2 to 1.8 and when running the upgrade script, I get the following:
Line 46 is:
but running 'desc escalations' on the DB (after the upgrade stops there), produces:
No status column... Any idea what I can do to fix this? (is it safe to comment this index line out until later?)
(Edit: Restored a backup and commented that line out anyway. Patch seemed to apply smoothly and I can't see any problems. Will I need to add this index later?)
Cheers,
Terry.
Converting database to UTF-8 Patching the database ERROR 1072 (42000) at line 46: Key column 'status' doesn't exist in table Failed to patch Zabbix database. Restore from backup
CREATE INDEX escalations_2 on escalations (status,nextcheck);
mysql> desc escalations; +--------------+-------------+------+-----+---------+----------------+ | Field | Type | Null | Key | Default | Extra | +--------------+-------------+------+-----+---------+----------------+ | escalationid | int(4) | NO | PRI | NULL | auto_increment | | name | varchar(64) | NO | UNI | 0 | | | dflt | int(2) | NO | | 0 | | +--------------+-------------+------+-----+---------+----------------+ 3 rows in set (0.00 sec)
Cheers,
Terry.
