Disable a trigger in a template
  • jay
    • Dec 2009
    • 11
    I found a strange behavoir on my zabbix.
    I temporary disabled a Trigger on a template and know I would like to re-enable it. It works on the template but It stay disabled on each host that have this template. I have to re-enable it on each host.
    any idea?
    Best regards
    Jay
  • richlv
    • Oct 2005
    • 3112
    which version of zabbix ?
    how exactly did you disable it, and how are you trying to enable it ?
    • jay
      • Dec 2009
      • 11
      I use the 1.8.
      Apparently, The problem occurs only on a specific trigger and I can't reproduce the behavior. I will post back the information if I arrive have this problem again.
      Thanks anyway for the response.
      Jay
