can't load images into database
  • Khach
    • Oct 2005
    I add the following line to /etc/my.cnf
    set-variable = max_allowed_packet=16M
    and restart mysqld (service mysqld restart)
    copy all the images to /tmp
    chmod 777 -R /tmp
    but still have the following error
    [root@wa05ids data]# cat images.sql |mysql -u root -p zabbix
    Enter password:
    ERROR 13 (HY000) at line 24: Can't get stat of '/tmp/Hub.png' (Errcode: 13)
    [root@wa05ids data]# ls -al /tmp/Hub.png
    -rwxrwxrwx 1 root root 1960 Oct 27 12:08 /tmp/Hub.png
    • acceleratebiz
      • Oct 2005
      • 12
      #17
      Here is my /etc/my.cnf file:
      [mysqld]
      datadir=/var/lib/mysql
      socket=/var/lib/mysql/mysql.sock
      set-variable=max_allowed_packet=100M
      [mysql.server]
      user=mysql
      basedir=/var/lib
      [safe_mysqld]
      err-log=/var/log/mysqld.log
      pid-file=/var/run/mysqld/mysqld.pid
      • acceleratebiz
        • Oct 2005
        • 12
        #18
        Enter password:
        no idea what that error is all about, sorry. Not experienced with mysql myself.
        • lofouk
          • Feb 2006
          • 14
          #19
          I ve got the same trouble when i begin the installation of Zabbix
          ERROR 13 (HY000) at line 24: Can't get stat of /home/zabbix/zabbix/create/data/images/hub.png
          I create a user with the same privilege of the ROOT user
          i am using Fedora Core 4.
          Mysql 4.1.11
          you know what is wrong ?
          Regards
          lofouk
          • felipegeek
            • Feb 2006
            I had exactly the same problem with the 'images.sql' part. I, like most users, put the Zabbix application in /home/zabbix. By default when the 'zabbix' user was created with 'useradd' the /home/zabbix folder was assigned '700' rights so no other user could read the contents of the '/home/zabbix' folder. After granting '755' rights it worked just fine. Another note: After extracting the current zabbix tar image make sure to rename the directory that was created which has the version number information on it to just 'zabbix'.
            BTW: This happened to me on CentOS 4.2 (RHEL4 GPL variant)
            -felipe
