last check in future
  • MarioF
    • Dec 2008
    • 10
    i had a problem with a linux server running zabbix was running fast. unfortuantely I made an error and forwarded there server onto October 2010. I realised my mistake and corrected it, but now my last check is still set to October 2010! Is there a way I can change this?
    my db is mysql v5.
    Mario
  • MarioF
    • Dec 2008
    • 10
    progress
    okay, so it looks like there is a nextcheck field under zabbix.items. I'm not sure what the sql should be to do a global replace to change the value of nextcheck to zero.
    if this the right thing to do?
    • MarioF
      • Dec 2008
      • 10
      Solved
      okay, i ran the following sql:
      update zabbix.items
      set nextcheck=0
      where nextcheck > 0 where hostid=<blah>
      once I was happy that things were working as expected, i removed the "where hostid" section.
